Results 1 to 10 of 16
Thread: Remote Wireless Tyre Monitor
    Nov 2008
    Gone
    After reading chris mack's post on his Defender rollover, I am going to look at buying a remote tyre monitor as it may give some warning of a tyre problem. Has anyone fitted one to their vehicle, and if so, suggestion as to who or where to purchase one from would be very helpfull.
    Allan
    Geelong, VIC
    Have a look here:
    Tyre Pressure Monitoring
    Steve
    Karalee Qld
    Hi Allan,
    I did a lot of reading and research on these. This is what I found...
    Tyre Dog brand and some other brands were considered but I read some mixed results with people swearing by them while other having issues. The main issue with these are:
    1. They are easily removed by people who want them more than you! They are also easily damaged off road. You can get a locking ring but a pain in the arse too when inflating/deflating your tyres. Also, a very short battery life on these sensors.
    2. You can get some brands which mount the sensor on the inside of the tyre (mounted to the rim) but a pain in the arse when you need to rotate your tyres.
    I saw a new brand (Inawise) at the 4x4 Show in Melbourne 2 years ago. The product looked good but I didn't purchase because while I like the idea, I wasn't convinced any of these on the market were any good and had drawbacks. I took a brochure and read up on it and it sounded like it overcame many of the issues I mentioned above. So, I went along to my local tyre place and asked them "Do you sell a TPMS system?" They did, think it was Sensatyre. I then showed them the Inawise brochure. They rang them and got a Rep out to talk them through it. They rang me back and said they had a look at what they were currently selling vs this new brand. They said this Inawise system was much better and it was also cheaper as well. They (Bridgestone dealer), now sell this brand instead. I bought a 6 wheel system so I could monitor my Camper Trailer. About 15K now and works a treat. Towed up to QLD & back to Melbourne at Christmas and it gives you confidence knowing what is going on. Interesting that my tyres increased 20% in pressure when driving.
    It is also easy to use off road. Lower your pressure to your desired amount, then hold the reset button on the back for 3 secs. It then adjusts to the new tyre pressure settings so your alarms won't continually go off. I also have sensors fitted to the spare on my Defender and also the Camper Trailer. These are not monitored. If you need to use your spare, you simply remove the round disc from the main controller and add the spare round disc. They are all labelled with a letter for easy identification.
    Have a look here...
    TPMS
    I am very happy with this set up - and not afilliated in any way with this business. Just wanted to pass on to you and anyone else considering one of these.
    Nigel
    SW of Geelong
    Nice review Nigel,
    I like the idea of the disks, allowing easy fitting of your spare.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Nov 2008
    Gone
    Quote Originally Posted by SVX37 View Post
    Hi Allan,
    I saw a new brand (Inawise) at the 4x4 Show in Melbourne 2 years ago. The product looked good but I didn't purchase because while I like the idea, I wasn't convinced any of these on the market were any good and had drawbacks. I took a brochure and read up on it and it sounded like it overcame many of the issues I mentioned above. So, I went along to my local tyre place and aked them "Do you sell a TPMS system?" They did, think it was Sensatyre. I then showed them the Inawise brochure. They rang them and got a Rep out to talk them through it. They rang me back and said they had a look at what they were currently selling vs this new brand. They said this Inawise system was much better and it was also cheaper as well. They (Bridgestone dealer), now sell this brand instead. I bought a 6 wheel system so I could monitor my Camper Trailer. About 15K now and works a treat. Towed up to QLD & back to Melbourne at Christmas and it gives you confidence knowing what is going on. Interesting that my tyres increased 20% in pressure when driving.
    Have a look here...
    TPMS
    Nigel
    Thank Nigel
    I am after a moniter I can move from the S.V.X. to the 90 when we want a change. I don't want to change wheels around on the two vehicles. Thanks for the imfo, will have to consult the banker.
    Allan
    Nov 2008
    Gone
    It may be a strange question but why move this post, it was a tyre/safety question
    Allan
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Hi Nigel , looks good and excellent report. I had also been looking at these.
    Trailair
    Gary
    Warragul, Victoria
    I was shopping around looking at the different systems and found that I prefer the internal sensor systems.
    However, the internal sensors which would suit the 130 Defender with its higher tyre pressures are really expensive compared to the car sensors which wont handle the higher pressures required of them.
    Geelong, VIC
    Hi Allan,
    Have a look here...
    TPMS
    Nigel
    Thanks for the review Nigel.
    I'm assuming you've just got the "car + trailer" version, and a couple of extra sensors to go on your spares.
    Steve
    Canberra, Australia
    I've been using a TyreDog system for a couple of years on vehicle and trailer. (early 6 wheel system) I could have returned and argued about sensor pressure accuracy, but two times, alarm has gone off when tyre got down to 22lbs where I had set the alarm. Not flat but plenty early enough to repair and reinflate. Saved two tyres (1 on vehicle rear and second on trailer) and no doubt lots of other angst if they had been run flat on dirt roads.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
