Results 1 to 9 of 9
Thread: GPS unit
    Irymple, Victoria, Australia
    GPS unit
    I am in the market for a GPS unit, probaly a hand held unit.
    The main reason I want it is for an accurate speedo in my series Landy.
    I have not been into town to check any out as yet.
    So at present I know sweet FA about them!
    Anyone have any suggestions of reasonable unit at a reasonable price that would suit the application.
    Cheers, Mick
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Jul 2009
    Hobart
    Hi,
    I would imagine that the hand held models would not suit your purpose with the speed display being so small.
    I have both, and the Navigator Garmin Nuvi has a large speedo display screen just one click away from the main navigation display.
    My son has an iphone that he can use as a head-up display. It shows a mirror image of the numerals that can be viewed in the reflective windscreen.
    The LR may not have enough shelf space, nor windscreen curve for this to be usable though.
    Thanks, I will check out the Navigator.
    I can't see the sense in an I Fone at $60 bucks a month for a glorified speedo....
    I could have another couple of series vehicles registered for that sort of gold.
    Thanks again,
    Mick
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Feb 2010
    Sutherland Shire, Sydney
    Quote Originally Posted by mick88 View Post
    <snip>The main reason I want it is for an accurate speedo</snip>
    I think we put too much credence in a speed reading from a GPS.
    I've got an iPad and an iPhone with an enhanced GPS receiver. Running the same software (Memory-Map on both or TomTom on both) they give different speed readings by several Km/h. This is on a straight road without tree cover with me trying to keep the speed as stable as possible. It's not consistent either - sometimes the iPad will read higher and at other times the iPhone will read higher. Sometimes I can get a (low) speed reading whilst parked. All I can put it down to in tolerances and inaccuracies inherent in satellite readings.
    Whilst driving on winding roads the problem is worse as the GPS approximates the distance traveled with a series of straight lines (between readings).
    Personally, my view is that a calibrated speedo is the most accurate measurement available.
    Feb 2009
    Newborough, VIC
    67.72 MB
    Quote Originally Posted by RVR110 View Post
    I find that the GPS speed from my Chinese GPS is accurate to the nearest 1kph at least 99% of the time, and just as accurate as a my speedo. Even on hills I find the GPS reads the same as my speedo (if you take into account the error caused by larger than standard tyres).
    Perhaps there is a bit more interference in Sydney, or your signal strength is not good.
    Mick,
    A cheap $60 GPS from china plonked on your windscreen will do the job, you are after.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Feb 2010
    Quote Originally Posted by biggin View Post
    It was "on a straight road without tree cover". It wasn't anywhere near Sydney or any other major city. But that's inconsequential - the overall point of what I was saying obviously wasn't adequately made. Oh well.
    May 2002
    Heathcote (in "The Shire")
    Might be more to do with the app you are using.
    Most receivers compute speed by a combination of movement per unit time and computing the doppler shift in the pseudo range signals from the satellites. The speed is smoothed and not instantaneous speed............................................. .................................Velocity measured by a GPS is inherently 3 dimension, but consumer GPS receivers only report 2D (horizontal) speed on their readout. Garmin's specifications quote 0.1mph accuracy but due to signal degredation problems noted above, perhaps 0.5mph accuracy in typical automobile applications would be what you can count on.
    A speed when you are parked can be due to a number of things, poor satellite geometry, multipath signals, obstructed view etc. Ipads etc also use assisted GPS where cell data or wifi is used in conjunction with the GPS to speed up acquisition (don't know what effect that may have)
    Feb 2010
    Quote Originally Posted by Bushie View Post
    I agree as this is exactly the point. Just because a device has a digital readout and is based on satellite telemetry does not make it "accurate". Every form of measurement has its inherent measurement uncertainty (aka error or inexactness).
    Len Guest
    GPS
    Mick,
    I know nothing on the pros and cons of accuracy but I have posted a GPS in the electronic for sale section.The unit has a fairly large speedo readout.
    Len
