First step in calibrating the suspension is to get the beast level.
These are measured from the center of the wheel hub to the bottom of the wheel arch moulding. Its a bit fiddly and a adjustable gauge of some sort is better than a tape measure.
The standard measurement for the D3 at normal height is:
Front 465 mm
Rear 482 mm
These are for veihcle unloaded but whith full tank of fuel.
Then adjust to what you want.
Ivan
PS D4 should be the same I guess
