Some basic things you may have already tried...
 1. make sure bluetooth is enabled on your phone - depending on the phone it can be easy to turn it off accidentally.
 2. if the BT was already active on the phone then try to pair another phone. If that works then then the issue is likely your phone rather than the LR unit.
If neither of the above help then something needs sorting out with the LR unit.
Sean
