Results 1 to 10 of 13
Thread: Fitting a winch
    fender22 Guest
    Fitting a winch
    Hi, I'm interested in fitting a winch to my 1993 200TDI 110.
    Have a fairly standard heavy duty steel bull bar but it doesn't have any
    particular mount for a winch however one could be bolted on to the
    front of it down low. Most winches I've seen seem to be fitted to a
    bull bar with a proper mount for a winch. Is there anything wrong with me
    bolting / adapting one direct to my bull bar?
    Mar 2010
    Mudgee-ish
    You will probably find that anything projecting forward of the bumper bar is illegal. I would imagine that a winch will be wider than your current bar.
    Oct 2010
    Ourimbah
    You could modify your existing bar to fix a winch correctly.
    Do a search on here. I have seen photos of it being done on here before.
    Nanny state UK...
    ...or you could not bother and save yourself the agro by carrying something more versatile - A hand winch.
    M
    Yinnar South, Vic
    Quote Originally Posted by camel_landy View Post
    M
    Pfft, I'd like to see you hand winch some of the hills around here, 100metres on a tirfor, yea......right
    Feb 2005
    some bars you can be lucky and they already have the winch holes pre-cut and only little notches that need knocked out......
    otherwise you could make your own cradle or drop into somewhere like ARB there cradle might be able to be adapted to fit
    post a pick of your front bar this will help us
    Nanny state UK...
    Quote Originally Posted by rovercare View Post
    Some wild assumptions going on here...
    Nanny state UK...
    OK... Well, let us start with the basics:
    What do you want the winch for?
    From there, we can argue the toss about what winch would be best suited for what you want it for and even if a winch is the best way forwards!
    If you're wanting to winch up these mega 100m hills, winch challenge events or similar... A Warn 8274 is probably what you're going to be after or a Husky (if you want a winch that'll be slower but can go all day without overheating).
    If you just want to self recover, I'd suggest the hand winch.
    There are various pros & cons to fitting a winch, all of which have been done to death on these pages, so a quick search should throw up all sorts of questions & answers.
    M
    Yinnar South, Vic
    How so? I've never needed a tirfor, but have needed a winch plenty of times, hand winching is a bad idea, it's hard arduous work, for little result
    Nanny state UK...
    Little result? If you're stuck in the middle of no-where and a quick backwards pull is all you need to get you out (which you can't do with a front mounted winch)... I think that's a great result!
    Anyway, the arguments have been done to death and I'm not going to resurrect them here.
    M
