Thread: Are centre diff locks able to be used in axles?
    Andrew Morris Guest
    Just wondering if it is realistic to use the centers from centre diffs and their diff locks in axles?
    I am here: http://tapatalk.com/map.php'toavsr
    Hi Andrew,
    Unfortunately not. They are in no way similar.
    Rgds
    Pete
    East-South-East Girt-By-Sea
    1.20 MB
    While were on the subject of CDL's - does anyone have any images of the internals? LT95 and LT230
    I do of the LT230
    see some pics about 1/2 way down this post: http://www.aulro.com/afvb/1593565-post350.html
    Hay Point
    Lt95 internals are near identical. Only difference is fine spline with LT230 and coarse with LT95. Cross shafts are interchangeable between both.
    Cheers......Brian
    1985 110 V8 County
    Jan 2010
    Newman WA
    Near Identical ??? !50 bits in each and the only one interchageable is the cross shafts .They may actually work under the same pinciples , but they are totally disimilar.
    Hay Point
    We're talking internals here. There's certainly not 50 parts there. Both CD's work on the same principle, 2 side gears and 4 pinions/thrust washers running on the same cross shafts.
    Cheers......Brian
    1985 110 V8 County
