Results 1 to 6 of 6
Thread: how do you removal the actual fog light from a bullbar??
    Nov 2007
    Okay I have had a squizz in and around the fog light but for the life of me can't suss out out to remove the fog light from behind the ARB bullbar. Need to remove the LHS one.
    Any clues????
    I know from the front there are 3 locating screws but these are not accessible through the bullbar.
    Cheers....
    New :- D3 TDV6 2006 SE
    Bullbar, traxide dual battery
    General grabber ATs
    Mitch hitch
    Home made drawer and fridge system
    Foldable UHF antenna on roof rail
    Sydney, Australia
    You need to remove the cover plates under the bull bar to get at the lights. LR one is tight to get at but possible. I removed mine to get rid of the fog in it as it wa obvious after the other was replaced.
    Nov 2007
    Thanks caverd3. Did you still have remove via the 3 front screws or was it possible to get out from the back?
    General grabber ATs
    Mitch hitch
    Nov 2007
    Hey CaverD3 just seen your write up at
    DISCO3.CO.UK - View topic - clean fog lights
    I thinks answers my above question.
    Cheers...
    General grabber ATs
    Mitch hitch
    I need to do this as well. I've been to the DISCO3 site and seen Caver's post. Is it only the two bolts at the very top of the fog light bracket that need undoing to get it out?
    I also can't tell if the bracket is attached to the indicators.
    The LHS one seems it's going to be a pita because of the washer fluid bottle.
    Any tips to make this easy welcome.
    Bob
    Done. Fiddly and much cussing but all cleaned and back together now.
