Took my Freelander 2 to the auto elecs today to have a look at the
trailer outlet. Hasn't worked since I bought the vehicle (2nd hand)
Has two outlets, I believe one is euro and the other Australian and I
assume factory fitted.
Anyway, not that I think he tried too hard but the auto electrician told me the trailer plug was infact dead and is controlled by a module. Not sure if he meant the module was dead or it didn't have one. Anyway he told me would cost a fortune to fix. Is there a master fuse or something I should be checking?
Alternately, could I run some wiring direct from the rear tail lights and just install another standard 7 pin outlet? I asked the electrician if he could do this instead and he said he was concerned it could effect the wiring or give the main computer false readings or something. Has anyone else had any experience with this?
