Thread: 7.50 r 16 tyres....HELP!
    May 2010
    Delegate NSW
    I am interested in getting a set of 7.50 r 16 tyres, but I am curious as to whether or not they will go on Range Rover Vogue rims? I have a gorgeous set of Vogue rims on my Defender, and Id rather stick with them than the steelies the tyres come with
    East-South-East Girt-By-Sea
    1.20 MB
    Am assuming that you have a set of alloys from a Vogue classic (rather than P38a or L322 Vogue). They are a 7" rim while the Defender rims are usually 6".
    Yes you can fit 7.50 tyres to them however there were only a small number of alloys that were rated for the Defender and they are the ones fitted to both the Disco 1 and Defender Xtreme.
    There are also many radial tyre sizes equivalent to the diameter of the 7.50 16 that are better for the 7" rims.
    While they will fit most tyres coming in the 7.50R16 format these days are light truck style tyres where as the decimal equivalents (
    235/85 R 16) have a wider variety of construction speed and load rates.
    you'll be working the sidewalls a bit with the 7.5's on a 7 inch wide rim and ID suggest that a slightly wider profile tyre will behave better on the wider rim
    (see previous comment)
    Apr 2010
    Connolly, WA
    Agree 100%...
    235/85/16 in any brand that strikes your fancy is definitely the way forward on those Rangie alloys, maybe even 255/85/16 if you feel adventurous!
    Apr 2010
    Blaxland,Blue Mountains
    Try 285/75/16 they make your speedo accurate as well
    regards
    wal
