                                                6th April 2012, 08:07 PM
			Wiring Loom question for a 1953 series 1
					I have a new wiring loom from the UK which has indicator wiring.
 As these extra wires are not on any wiring loom diagram it is hard to fiugre out where the wires go in the dash.
 4 wires for L/H and R/H wires back and front.
 1 Green power lead?
 3 green wires with spade clips? (unless these are for the indicator tumbler)
 Going to use the Trafficator Switch for the indicators ( it has a tell tail light so should pass  a road worthy )
 Malcolm
                                                9th April 2012, 06:12 PM
			indicators
					This all depends on how you want to d it. I have a 48(+earth) wired to the trafficator switch and to cut down on the number of wires needing to run up to the switch. These wires need to run up the flexible steel conduit with power for the wiper. I use 2 cans, can dig out my diagram and post it if you want. Has worked for 10 years without changing a can.
 Remember it is road worthy without indicators but I would fit them.
 Dennis
