there are a few common methods for dual tank operation in a diesel with a lift pump on the engine...
does each tank have its own filler or is the filler common to both tanks?
do you know if the spill-back from the injection pump goes just to one tank?
what type of diesel engine is it (200 or 300tdi, 4bd1, td5 etc) ?
if, as you say, there is an electric pump sound when you switch it on, then it could just be a simple transfer top-up to the main - if so try switching it on for a few minutes and see if the fuel gauge shows a content increase.
