                                                9th April 2012, 06:42 AM
			vibration through driveline
					Hey all. just need to find out a few things on where to start with my problem. i have a slight vibration through the driveline mainly felt through the front (accel pedal, gear lever now through the body) I havent owned the 110 very long but its starting to get annoying coz it wasnt there when I first picked it up. you can really notice it cruising about 80kmh with low load.
 any help would be appreciated cheers.
                                                9th April 2012, 06:57 AM
					mate,get straight under and check the uni's on the drive shafts do it today not tomorrow,if one lets go it will cost big time.
                                                9th April 2012, 09:32 AM
					Hi mate, I have the same thing and it is the uni, mine squeaks though, not so much vibration. I ordered some HD unis from britparts who are reasonably cheap and should have them here by Tuesday or Wednesday and will post a thread for all us noobs on how to replace them.
 Pete
                                                9th April 2012, 02:12 PM
                                                #4
					Check uni's and slip joint as well. Hardy spicer have uni joints and can check if you are not sure.
                                                9th April 2012, 08:16 PM
                                                #5
					Check all steering bushes especially panhard rod
