 Originally Posted by
zulu Delta 534
				How many different styles of standard bumperbars were fitted to the early 80" S1s?
I am aware of the difference of the early fishplate chassis mounts but was wondering about the differences in rear stiffening panels, mounting plate thicknesses etc. on the later bars. Did the mount width change when the spring hangers moved from the front of the springs to the back?
Were there any discrepancies re dimensions of the bar itself in those early days, narrower, thicker, denser materials etc?
I am aware that there were differences between the 86/107 models with the thicker bottom mounting plates compared to the later 88/109s with narrower bottom plates, but my query mainly concerns 80inch models as we are contemplating a limited run of these in the near future provided we can collate the correct information to satisfy various different vehicles.
I am also in the throes of remanufacturing the 90deg. elbow that goes from the rubber connecting hose to the air cleaner body and would appreciate any detailed photographs of the original item specifically showing its clamping system to the cleaner as well as the hose/pipe position to the sump breather pipe!
Glen
