Results 1 to 10 of 19
Thread: Alternative to rear bar.
    Platypus Guest
    There has been much discussion on Rock Sliders to protect the underside of the sills.
    Is/are there alternative(s) to the Heavy duty Kaymar rear bar. Yes it does the job of protection but it is a massive piece of metal work, heavy and not inconsiderable in cost.
    I was wondering whether a rock slider type of structure exists which would still offer underside protection when climbing down steps or large rocks but was not quite as, well, massive as the Kaymar?
    Could one be fabricated?
    Is the Kaymar actually the minimum it needs to be to protect the overhang of the D3/4?
    PaulB
    You've been reading my mind! That's my "May Project" ........
    Gordon
    Dandenong Ranges - Victoria
    Will be watching.
    Maybe with ability to option a jerry can carrier?
    We are not all looking for extended range beyond what 1x 20L jerry gives.
    Dec 2011
    Forrestfield WA
    Quote Originally Posted by gghaggis View Post
    Gordon
    Gordon,
    You can make an aluminium bar for my car if you like, provided it will be compatible with the Kaymar spare wheel holders. I would love to shed some weight from the back.
    Don't forget to finish my front guard though!!!
    Bob Davies
    Discovery 4 3l SE
    Kaymar rear bar
    ECB Bull Bar
    Brown Davis long range fuel tank
    Mitch Hitch
    Llams
    Traxide USI 160 dual battery kit
    GME UHF Radio
    GOE 18 inch wheels
    Feb 2009
    Gordon
    How'd you go with that one, Gordon? If it's like my "May Projects", they're now "July Projects"...
    Quote Originally Posted by Stuart02 View Post
    Sigh - yup!
    Gordon
    The weight of a Kaymar Bar is only a very minor increase percentage to the D3/4. Adding a net 40 kgs to a vehicle weighing nearly 3,000 kgs, just over 1%.
    South Sydney
    But it comes out of your payload, which is what people don't like.
    mandurah
    Quote Originally Posted by Desert Traveller View Post
    I would like to see confirmation of that weight. The Kaymar setups are basically the same configeration for all 4WD's they cater for. Having tried to pick up a Patrol twin carrier setup, there is sight more difference than 40kg's, once you take off the std bumper and bracing. Based on a basic setup with one tyre carrier, I reckon you would be looking at least twice that figure. Add another swing arm and carrier with rim/tyre, and there is another 45- 50 kilos. The D3/4 vehicle weight including a tank of fuel, is closer to 2500 kilos than the often quoted 3000.
    ...but yes in the overall scheme of things, the weight is not a lot. Add on a bullbar, aux. tank & roofrack, and it's starting to get up there.
    D4 2.7litre
    Feb 2010
    Mount Martha
    New Rear & Front Bars
    Check out this site paragolpes LandRover - TRC Off Road
    Cheers, Craig
