Results 1 to 10 of 15
Thread: Towing a trailer purchased at auction
    Mildura,NW VIC
    Hi all,
    Have just purchased a track trailer at Pickles Tamworth.Apparently it's still registered but no plates.As i need to tow it to Vic how do i go about it ? Do I need a permit?Who to contact Will leave Mildura Sat and be in Tammy Monday.Your advise will be welcome,
    Mary
    "Some people walk in the rain,others just get wet!" -Roger Miller
    do you own a registered trailer already?
    Mildura,NW VIC
    Yep do but VIC rego
    Western Victoria
    If it is registered, it must have plates.
    No plates, you can assume not registered.
    To tow an unregistered trailer, strictly speaking you must have a permit issued in the state it originated from.
    Unregistered vehicle permit : VicRoads
    I have been with people in NSW with Victorian exempt trailer plates. The local boys in blue booked them for having unregistered trailers. The Vic exempt trailer plate is only recognised in Victoria.
    Alternatively, borrow a trailer to transport the Track trailer on.
    Which Track trailer is it? An ex RAAF? The civilian version of the RAAF one? The camper? The T-Van? The Topaz?
    Oct 2007
    wetherill park
    You can get an unregistered veh permit from the NSW roads and maritine here is a link
    Unregistered Vehicle Permits (UVPs)
    havent used a nsw one, hope it is as easy as vic rosd permit
    Western Victoria
    I tried to get an unregistered vehicle permit in NSW a couple of times.
    They wouldn't issue one without a NSW address and a pink slip.
    I told them they were useless bureaucrats on several occasions. Made no difference.
    Oct 2007
    wetherill park
    NSW address is not a problem( I have one) but the pink/blue slip will have to be done after pick up but if its been registered in nsw before its not hard just pay the money
    Western Victoria
    There's your answer Mary, with The Booger's help.
    Is it the civvy version of the RAAF ones? There was one at Pickles a month or so back.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Hoges View Post
    Be very careful using the plates from one trailer or motor vehicle on another trailer or motor vehicle.
    The fines for an unregistered vehicle is something in the order of $1,500 and some demerit points.
    The fine for false prentences can be tens of thousands of dollars and a prison sentence.
    So the risk of an unregistered trailer is potentially much less than a charge of fraud and a criminal record.
    Get an unregistered vehicle permit.
    BTW an UVP must be issued in the state where the journey commences. You only need a safety inspection report (pink slip) not a blue slip. If the RMS give you problems state the reason is to remove the trailer from NSW to Vic for re-registration in Vic, you therefore do not have a NSW address. If they don't accept that, ask to see their supervisor, stand your ground and keep going up the heirachy until you get to the Minister for Transport. His name is The Hon. Duncan Gay.
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by malleefowl View Post
    Hi all,
    Mary
    The trailer needs to be roadworthy, you will need a pink slip, tell the pink slip issuer it is for a permit to tow an unregistered trailer, take the pink slip, your reciept, any chassis numbers to the nearest RTA office and they will issue you with a permit. If there are no chassis numbers you will have to get/pay the pink slip bloke to stamp a number on the drawbar usually issued by the RTA, good luck, Regards Frank.
