Results 1 to 10 of 16
Thread: headlight 7" crystal inserts.
    Torres Straits
    so my head lamps have seen better days, stone chipped and cracked.
    Is it worth grabbing this sort of thing
    eBay Australia: Buy new & used fashion, electronics & home d
    Or better off without the crystal bling? Is it just bling or do the crystal reflectors actually provide better light pattern?
    Steve
    NSW far north coast
    Steve, in theory a good free form reflector should work really well, but I haven't seen a 7" round headlight out light my 7" Cibié Z beams yet.
    It helps that the Cibiés are all metal so i can run a little more than 60/55w globes too
    I am a bit confused - are these HIDs (Xenons) or Halogen - the ad says both but there is no ballast if HIDs.
    Torres Straits
    hmm,
    Seems the z beam is no longer made production finished early '90s
    They certainly get the wrap though?
    Replaced by cibie ece or e code lamps - Can source them for $78US each plus delivery plus globes.
    Hmmm
    S
    NSW far north coast
    Don't buy headlights from the US, the cut off pattern is all wrong, it's for LHD.
    I bought a new Z beam about four years ago to replace one a rock had gone clean through and AFAIK they are still available ?
    [edit] Hansa in Melbourne used to be the Oz importer. A mate of mine used to manage Race and Rally and that's who got me the last one I needed, but they've gone belly up now.
    Apr 2010
    Connolly, WA
    Steve,
    Have a trawl around the UK suppliers' websites before you make your decision. With the winter gloom over there it is pretty much standard to do serious headlight upgrades to all pre-Td5 Defenders and the options and choices are quite significant.
    Yass NSW
    SWMBO has a wrangler and I have done some research on current options, the notional best choice would be the Britax headlights, available from most truck spares shops. these have a metal reflector and polycarbonate lense.
    Headlight Insert | Polycarbonate | 7" 178mm | Xenon HID Upgrade Kits | Britax Automotive Equipment
    Regards,
    Tote
    NSW far north coast
    Steve, I just sent an email to a mate at Revolution Racegear on availability of the Cibié headlight.
    FWIW the part # of the last Cibié headlight I bought is 082441/60, code 082441.
    Hella make a very good H4 headlight too, they may be more available.
    Central Coast NSW
    Why not use SVX head lights,
    Clear poly carbon lense, ADR approved.
    NSW far north coast
    Quote Originally Posted by Drover View Post
    With glass lenses and steel reflectors you can use higher wattage globes
