Thread: Front Propshaft refit...
    Superhux Guest
    Hi guys,
    I have since had my front propshaft rebuilt as the UJ seized and sheared the yolk and totally pulled the shaft apart at the transfer case... Luckily it was at low speed i.e. <5km/h... all because I recognised the familiar metal on metal grinding sound....
    Once it was rebuilt I read that it should've been rebuilt out of phase, however this was rebuilt and BALANCED back in phase.... Is this going to be a problem as also read that it was only to make it more adaptable to different levels...???
    Also if it isn't a problem how do I get the bolts in the transfer case end???? Do I have to take that massive bolt out and move the flange forward???
    Dave Huxtable
    1997 300Tdi
    295000 km
    It'sNotWorthComplaining! Guest
    Quote Originally Posted by Superhux View Post
    Hi guys,
    Dave Huxtable
    1997 300Tdi
    295000 km
    If you are talking about the bolts on the output flange that hold the tail shaft on ,then to remove them you will have to undo that big nut to remove the out-put flange, ( 30 mm I think) as the bolt heads are retained behind it by a big c clip, that's what hold the bolt heads forward.
    A rattle gun makes eay work, you'll also need a new felt washer when refitting and It would be good to replace the oil seal whilst your at it.
    South Sydney
    I think what he means is the prop shaft cam apart and it was put together, but intead of the yolks being 90 degrees opposing they are aligned ???, should be okay, but may vibrate a little which will lead to premature uni wear
    Safety Bay
    The uni's should be 45 degree's. Pat
    Mar 2009
    Near Geelong, Vic.
    Attaching the propshaft.
    **Also if it isn't a problem how do I get the bolts in the transfer case end???? Do I have to take that massive bolt out and move the flange forward???**
    Dave, is this appropriate?
    http://www.aulro.com/afvb/series-2-2...ark-brake.html
    If pictures are too small, right click & select "open in new window"
