Be careful with the bolts on the vents. I've had a couple snap off
For me, it was a matter of driving out the 2 hinge pins, then remove the 2 screws that hold the controls to the dash, then gently maneuver the whole thing out.
...... But yes, if your vent bolts are ok, that would be the easiest way to go, I think.
AND with a bit of electrickery I am fitting a 2001 Defender electronic speedo and transducer too, to get rid of the needle flicker and gain some accuracy!
