Results 1 to 10 of 12
Thread: Fitting Trailer Brakes
    C00P Guest
    Hi Folks,
    My off-road camper trailer (a new acquisition) has no brakes. The Series III LWB that we intend to pull it with has a limit of 500kg without brakes, 2000kg with brakes. Dunno the trailer's weight but it's probably approaching the limit and would certainly be over it when loaded. And anyway, legal or not, I figure my Series III's unassisted drum brakes can do with a little help when towing something.
    Having done some research, I figured that electric brakes were the way to go. My brother can supply a second-hand (good working order) proportional brake controller (dunno the brand yet, but he says it has the pendulum mechanism) so fitting the new brakes is all I have to do. Looking at some of the kits and instructional videos on the web, I figure this is within my mechanical capabilities, except for welding the flange onto the axles- the bit that the backing plates bolt onto.
    So, here's what I plan to do:
    (1) Jack the trailer and support it on stands under the chassis.
    (2) Remove the wheels.
    (3) Unbolt the U-Bolts holding the axle to the leaf springs and remove the axle and hubs (May have to remove one hub if it won't fit between the spring and the chassis).
    (4) Take the axle and hubs to a trailer place, and get them to supply an electric brake kit and also weld the flanges onto the axle.
    (5) Refit the axle.
    (6) Install the backing plates and new hubs/drums.
    (7)Wire up the brakes.
    (8) Install and wire the controller on the dash.
    A few questions for anyone here who is knowledgeable about these matters:
    Does all of the wiring for the trailer brakes go through the 7-pin plug we use here in SA or is an additional plug needed?
    From what I've read, I gather the brake magnets are wired in series. Is this correct?
    What size drums do you think I need? I figure they won't need to be very large, but have no idea of what governs the size, although I assume it is related to the size/weight of the trailer they are trying to stop.
    Finally, is there anything you think I've missed, and is this a reasonable approach for a relatively inexperienced spanner-weilder? (I don't have any problems with 12 volt electrics, but I've not played around much with suspensions/brakes).
    I've included some pictures so you can see what I'm tackling. Any suggestions and advice gratefully received,
    Coop
    Oh, and in case anyone is wondering, the hubs are a six-stud pattern, but I dunno what size/make.
    Jul 2007
    Sounds ok to me.
    I think you will be fine with a seven pin plug.
    How the electromagnets are wired is not important, you will have to run a wire to each drum.
    I think the electric brakes come in 12 inch and 10 inch. Don't know off the top of my head if there are any smaller, a quick google search should verify. The 10 inch drums should be fine for a camper trailer.
    The seven pin will be fine, it works off your brake lights and the controller that you fit to the vehicle will vary the voltage to the magnets which will then vary the pressure used by the brakes.
    Series 11A ex Air Force
    1995 ES Discovery TDI
    RIP 2006 Discovery 3
    RIP 2004 V8 Discovery
    RIP 95 Discovery TDI
    RIP 1999 Freelander
    RIP 1978 EX Army FFR
    Manly QLD
    Sounds like a good plan.
    Your 6 stud hubs will be Land Cruiser (Prior to 100 series). All the Jap 6 stud 4x4 wheels have the same std pattern but the wheels have different offsets. In the varies trailer parts catalogues they are just called 6 stud Landcruiser.
    The 7 pin may be OK provided that the 12V supply cable to the magnets has sufficient capacity for the 'juice' required.
    The tail light feed is used to trigger the controller...that's all. The controller then switches the required current from a 'heavy duty' 12V source to the supply cable.
    FWIW: for the 12V supply, use 10 or 12 SWG with a 30 Amp fuse direct connect to the car battery to the controller and from there to the designated pin on the 7 pin connector. The same gauge cable is then run to one of the magnets and then across to the other one so they are in parallel. Ensure you have a good earth between vehicle and trailer. The 'feed' from the tail light should be able to be tapped from the brake pedal switch.
    Make sure you get "off road" magnets ...they are better quality and mounted differently to absorb the corrugations.
    I went through the same rigmarole a couple of years ago and ended up choosing the Alko 10" drums/hubs/off road magnets/ shock absorbers and Tekonsha P3 controller for a home built camper.
    Another thought: It could be worthwhile to get the trailer place to weld an additional set of spring location pads to the axle 180 deg from the existing ones so that you have the option of mounting the axle above or below the camper springs depending on how much clearance you want/need. If you simply rotate the axle you will have to rewire/refit the magnets because they are uni-directional... just a thought
    C00P Guest
    Quote Originally Posted by harlie View Post
    Thanks Harlie, I just KNEW someone here would recognise them and tell me what they are! That's the sort of information I need to give to the trailer place that is supplying the parts for me.
    Coop
    C00P Guest
    [QUOTE=Hoges;1667427]The 7 pin may be OK provided that the 12V supply cable to the magnets has sufficient capacity for the 'juice' required.
    Thanks Hoges. I had read that I should use 6mm cable, but they didn't specify if that was the conductor or included the insulation! Having the SWG specification will ensure I get the right stuff.
    Didn't know such things existed. Thanks again- will do. Some of the roads I've been down of late would rattle the fillings from your teeth....
    I'll give them some thought. I'm lucky in that my brother will provide a used proportional controller that he no longer needs, so that will save some dosh. You will note my trailer doesn't have shocks, do you think I should fit them?
    Another thought: It could be worthwhile to get the trailer place to weld an additional set of spring location pads to the axle 180 deg from the existing ones so that you have the option of mounting the axle above or below the camper springs depending on how much clearance you want/need. If you simply rotate the axle you will have to rewire/refit the magnets because they are uni-directional... just a thought[/QUOTE]
    I thought the square axle was just U-bolted to the springs? I guess I'll find out this weekend when I take it apart. But that sounds like a good idea if I decide to re-position the axle for higher clearance.
    Thanks again Hoges- some excellent advice and information there. My wife, who has been looking over my shoulder as I type this, reckons this is like a "men's shed" on the internet.
    Coop
    The square axle is an excellent choice...much stronger. However it needs a "mechanical" way of locating relative to the spring. There is usually a bolt through the centre of the leaf spring holding the leaves together at the "apex". The head of the bolt rests in a hole in the pad welded to the axle so that it sits flush. It therefore stops the axle creeping out of alignment. I'm presuming a similar situation applies to square axles ...or one face of the axle is drilled to provide a shallow hole to acommodate the bolt head. Either way would probably work as well.
    6 gauge is 13 sq mm wire cross-section excluding insulation...far too big to fit the 7 pin plug. I actually bought a Narva 12 pin plug with two rows of 6 receptors. It cost about $20. 6 of the pins accept heavy gauge wire including that for the brakes. The smaller pins are for stop/tail/indicator/reversing lights etc. The other large pins I use for a couple of (12v) power outlets on the camper for lights and a small multi-band radio.
    For the fridge etc I have separate 6g twin cable which connects through Anderson plugs to the camper and doubles for charging camper batteries on the go using one of Traxide's magic boxes...
    "Every boy needs a shed!"
    EDIT: I found the shocks to be excellent. You need a compliant suspension for trailers on corrugated roads...not too soft and certainly not "heavy duty" in terms of high spring rates...depending of course on the load.
    I had 4-leaf Alko springs originally and ended up removing the small 4th leaf . With small trailer-specific shocks bolted on it made a world of difference... rode the bumps very well
    Manly QLD
    Interesting, I see Dexter US is now making self adjusting electric brakes called Nev-R-Adjust. That would be cool.
    C00P Guest
    Thanks Again Hoges, that's excellent information. About ready to break out the spanners and get stuck in this evening.
    Coop
    Edit: It all came apart much easier than I expected. There are two pads sitting between the axle and the springs. One was welded on and the other had been, but the weld cracked and it came off. I'll get the company to weld it back on.
