Originally Posted by
MLD
Hi Jon,
Dealing with your first point. When declining rock steps I'm moderating speed using the anti-stall speed while depressing the clutch a smidge to take pressure off the driveline and braking as required. If i didn't depress the clutch I'd fly off the ledge or stall by braking too hard to arrest the speed. In effect i'm using the clutch as an accelerator by engaging drive as required.
As to inclining rock steps: What i'm experiencing is probably what you describe as the line between anti-stall operating and me lightly pressing the accelerator thus disengaging the anti-stall. A flat spot where I feel there is inadequate drive because I've put the ECU in two minds. I then accelerate thinking it wants to stall.
I'm out and about this weekend weather permitting and i'll modify my driving to see if I am the problem. Will still need to resolve the fly like an Eagle attitude to declining rocks.
Bruce Davis said he'd play with the truck to see what the problem is and if it's the ECU map. There will be a solution.
thanks for the advice Frenchie and Jon.
Mark
