Thread: Whitworth Spanners on special - for the series drivers
    Logan Village area S.E. QLD
    At our local tool supplier, Whitworth Spanners are $89.00 for a 9 piece combination set, which is pretty good value the web site for your local supplier ...Home Page | Australian Industrial Supplies | AIS
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I've got a set of whitworth/ba spanners circa 1920 you can have for $89 each......not each set.....each spanner
    May 2009
    Tatura, Vic
    You really only need three sizes. 3/16, 1/4 and 5/16. All the other sizes there is a metric or imperial equivalent.
    Dave.
    richard4u2 Guest
    i think that should be 89c not $89
    Narre Warren South
    Quote Originally Posted by Mr Whippy View Post
    Dave.
    Similar discussion going on in the Series 1 section.....
    Some spanner size comparisons here:_
    BSW,BS,,AF,BA and metric tool size equivalents.
    If you work on an early Series vehicle then it would make sense to get a set of good quality Whitworth spanners. I've had mine for nearly 40 years and buy them now from trash & treasure markets. Sidchrome's for $1 to $2 if you're lucky, mind you, you've got to haggle.....
    Thanks for the 'heads up' Ho Hars.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Qld.
    Quote Originally Posted by ramblingboy42 View Post
    If they are attached to a 1920 Bentley (or similar) you're on!
    2007 Defender 110
    1993 BMW R100LT
    May 2009
    Tatura, Vic
    Quote Originally Posted by gromit View Post
    Colin
    I do the same when it comes to 1/4 and 5/16 whitworth. As I stated earlier, no other sizes are needed, (apart from 3/16) and the link above showing metric and imperial equivalents backs up my claim.
    I have a stack of old sidchrome whitworth spanners and the only ones I use are the three I referred to earlier.
    Dave.
    Narre Warren South
    Dave.
    I wouldn't agree that the link backs up your claim, it depends on how well you want the spanner to fit and also the quality (tolerance) of your spanners.
    Because I have a full set of Whitworth (BSF) spanners & sockets I use them. The only one that I sometimes use is 7/16" AF for 3/16" Whitworth but it depends on what brand of spanner the 7/16" AF is because sometimes it just won't fit.
    Each to their own.....I'd still recommend using the right tool for the job. Let me know what you want for the old Whitworth Sidchromes........
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2009
    Tatura, Vic
    Colin. Although I never use them I am a tool hoarder, so not for sale.
    As for using the right tool for the job I could not agree more, but you also need to be realistic. Today I adjusted the chain on my motor bike. I had to loosen the axle. Being a Jap bike, all the nuts and bolts are metric, but I did not have a metric socket big enough. I found an inch and a quarter imperial socket to be a perfect fit, but technically is not the right tool as the nut is metric. I am not going to go out and purchase a metric spanner when the imperial was a good fit.
    An 18 mm spanner is two thousands of an inch different to a 3/8 whitworth.
    I reckon many tool manufacturers would probably have a +/- one thou tolerance in their tools. Most larger whitworths have a very close MM or imperial equivalent, and when the bolts are large a slightly loose fit does not matter. If the bolt head or tool is not damaged it is a good fit.
    Dave.
    Colin
    Dave.
    OK you pair, settle petel.....
    I agree with tolerances of some spanners, yes they don't quite fit...yes we have a BIG chart up on the wall to show the comparison sizes and works well
    I put this thread up up for people that need spanners...please leave it that way and take youre opinions elsewhere
    Mrs hh
    Series Landy Rescue
    Our FB Page..
