Results 1 to 6 of 6
Thread: oil seals and groove in shaft
    Shepparton
    I am working on a Spicer Model 18 transfer case and need to replace a couple of oil seals.
    One on the shafts that the oil seal sits on has a very small groove where the seal sits. I do not have access to a lathe. Can I fill the groove with something like JB weld and sand back with some fine wet and dry sand paper?
    What would be the best filler to use?
    NSW far north coast
    Can you reposition the seal slightly so it doesn't run in the old track or can you use a Speedi-Sleeve ?
    Avoca Beach
    I may be wrong but IMHO JB weld will not work when there is constant rubbing.
    Just move the seal a bit , or it is possible in some circumstances to get offset seals. I fall else fails a speedisleeve but remember to put some sealant inside the sleeve. I did one once and the oil still flowed out between the sleeve and the shaft.Doh!
    Regards Philip A
    Moruya Heads/Sth. Coast, NSW
    As PhilipA says, I always (if the groove is deep) fill the groove with Devcon epoxy metal filler and sand smooth, then I push on a speedy sleeve with some Loctite sealer. Filling the groove will stop the speedy sleeve being formed into another groove by the new seal, Regards Frank.
    Shepparton
    I will have to google speedie sleeve, I have heard of them and it did not even enter my mind.
    Can you get them from a bearing specialist?
    Geelong, VIC
    Yes, any decent bearing specialist will have them.
    Steve
