Thread: Defender Long term storage
    Aug 2010
    Tennant Creek
    Hey everyone,
    My wife and I have the oppourtunity to take an overseas job for the next 3-5 years.
    What do I need to do to be able to store my 2002 110 td5 so when we return it will be minimal effort to start ie charge battery, change oil etc. I have access to a corner of a large shed where it can sit under a tarp or car cover. Is there anything else you guys recommend.
    Thanks in advance.
    Paul
    Jan 2010
    5 years is a long time!
    First thoughts:
    - Take the battery out
    - if you leave it sitting on good tyres they will probably need replacing after 5 years without rotation.
    - maybe an idea to sacrifice a full tank of diesel to keep moisture out, drain on return?
    - leave it with some fresh/strong coolant/anti-freeze
    - when you get back change ALL fluids and filters
    can you do much more than that?
    I've only ever left mine for a year at a time but it was left outside through some very cold uk winters and I didnt do anything other than make sure there was enough anti-freeze in the coolant system. I would come back to it, take the car cover off, start it up and drive it to the gas station for a fill up and then to a garage for a service. Twice I've had it stored for over a year and both times it started instantly on return, didnt even disconnect the battery!
    Jun 2008
    Castle Hill, Sydney, NSW
    Quote Originally Posted by manic View Post
    You can solve this by sitting the vehicle on axle-stands, keeping the tyres off the ground.
    Oct 2011
    North West Vic
    place on vehicle stands, nitrogen in tyres so it leasks slower.
    full oil change. put in neutral so someone can turn tyres occasionally to oil gears.
    rat traps, roach baits a big bicarb soda on plate for smells and moisture.
    pull injectors and put 2 stroke oil direct into pots and turn a couple times.
    refit injectors
    leave doors ajar to stop door seals sticking.
    full tank with diesel power additive to adsorb oil.
    when you get back full oil change and fuel change.
    you realy want someone to turn the engine and wheels buy hand every 6 months.
    it could be worth paying someone to do that for you.
    i am willing to look after it and keep it serviced and regularly used to prevent all the obvious problems arising,
    you might like to consider my offer,
    i will need the vehicle shipped to the gold coast, or i can pop over there to pick her up and bring her back here for safe keeping.
    i am prepared to send accounts for her runnung costs and upkeep to any address you nominate or establish regular withdrawals from your account for her upkeep.
    Safe Travels
    harry
    Didge Guest
    Damn you Harry, you just beat me. You must be more thoughtful and considerate
    Nanny state UK...
    Everyone has pretty much covered it:
    Get her fully serviced.
    Re-grease everything, props, etc...
    Full tank of fuel.
    Remove battery.
    Axle stands.
    I'm assuming that it is being stored indoors??
    When you get back, change all fluids & filters. (Hydraulic, oils, fuel, etc...)
    M
