 Originally Posted by
uninformed
				I have a Mile Maker running off a MD pto with cross hyd pump. System is designed to flow 60ltr/min. I have a 12v solinoide control valve with a simple push button cable remote. I had a double over center valve fitted directly to the winch motor as these winches have no brake, which is ok until you loose fluid! I am very happy with the system. The only bad comment on the winch is the powder coating is blistering off the cast alloy housing. Resivour holds approx 20ltr's and has in tank filters. System runs through a proper spin on filter. Pressure relief valve is set for stall load.
