Hi Baz,
The defender and discovery td5 intercoolers are different. one is longer than the other. there are also early and late model td5 intercoolers for each. so 4 in total td5 intercoolers.
The radiator for the td5s has a recess each side too allow the intake/oulet pipes to fit.
You would have to take your radiator/ intercooler out. centre the radiator, have new engine oil cooler lines made, new cooling pipes made, and new intercooler pipes made.
If you say fit an evaporator where the cooler is, the intercooler pipes wont fit around the radiator/evaporator setup as the pipes would need to come through there. An alternative maybe a intercooler from say a toyota soarer or something that is full width but has the inlet/outlet on the same side so you dont have too move the radiator.
An alternative would be to use a td5 radiator which is aluminium which has a better cooling ability than your radiator, but as they dont have an engine oil cooler built in you will have to buy an aftermarket one and make new oil cooler lines.
Iam interested as my brother in law has a 300 tdi defender and we have discussed this many times.... We already have the 02 onwards later model defender nose cone set aside for the conversion. to fit the intercooler in.
