so a water leak?
When you park the rear so its higher is the leak worse or not...if its not parked higher do I have it right that you then get a leak in the back? im finding it a little hard to understand your descritpion
a lot of leaks can be causes by the water coming from the roof gutter and down in through the door seal at the top corner near the A pillar, a bit of sikaflex just at the end of the gutter can prevent this if thats what happening...
some other leaks in to the foot well can also be holes in your firewall have you checked your firewall isn't rusted? although if your getting water in the back then not likely to be your firewall
