The TDCi is "drive by wire", (so unless you want to connect something directly to your accelerator pedal), no.
 Fossicker
						Fossicker
						Is it possible to fit a hand throttle to a new Defender? Will it act as a quasi cruise control?
May be a less precise but way cheaper alternative to an aftermarket electronic control.
Any advice would be appreciated.
the flybywire vehicles make it easier sometimes, there are a few vehicles that use the throttle pedal and link to a pull cable with graduated stops for this application, toyota for one.
jc
A simple system like that probably doesn't automatically disengage when you touch the brake. Could be dangerous.
I can tell you that when I was a passenger in a friend's Series II and he decided to use the hand throttle as a cruise control somewhere out near Broken Hill, things got pretty interesting when we came over the crest of a slight rise and found a mob of sheep blocking the road.
I want a "hand" throttle for when I'm using the winch, or wanting a very steady low speed, for arguments sake, say going up a rocky section of track, would using like an old mower type throttle cable be ok do you reckon?
I had a wind out hand throttle on my old 75 series toyo, (fitted from new at the factory) and yes, a as cruise control, was a nightmare,,
Chops
 ChatterBox
						ChatterBox
						There are hand throttles on the veteran cars, absolutely ****** dangerous to use as a cruise control, don't do it. I'd hate to see what the insurance company would have to say when you become unconscious after running up the back of an L plater, bouncing off the steering wheel and taking out the opposite two lanes when travelling down a dual carriage way, sure for small offroad applications to be able to bring the revs up ~ 250 rpm is good, but cruise control is a big NO NO. Needs to cancel on the brakes. Just fit one of the aftermarket systems, maybe you could do a little hotwiring to make it work at low speeds (low revs) and in neutral, then it could be used offroad and also safely on the road.
Will
Actually a hand throttle would be handy in low range crawling.
The cruise control won't work in low range.
I really would like hand throttle on my TD5 for winching, also would be handy to have a pot in the engine bay to give the engine a rev when listening to noises.
Thinking of running a pot in parallel with the pedal pot and see what happens.
 ChatterBox
						ChatterBox
						Why does it not work in low range, is there some kind of switch?, otherwise i can't see any reason a sytem couldn't be adapted to work in low or as you say just put a pot in parallel, you could have one in the cab on a screw like in a cruiser, would be really good offroad.
Will
I don't know why but as far as I know, no cruise control will work below 30kph.
The more I think about it a pot on the dash with a missile switch to isolate it seems very useful.
