Results 1 to 2 of 2
Thread: Ross Torqmotor specs
    NSW SW Slopes
    I have an hydraulic motor for which I have been unable to find specs. It was fitted to a 4" auger that I bought s/h 10-12 years ago and I'm hoping its capable of running at close to 540 rpm to drive a 120 L/min boom spray pump.
    On the label it has:
    MK050
    D/C 2 01 96
    Part No. MK031009AAAB.
    Can anyone help with the specs - max rpm and flow rate and pressure ranges? The AB on the end refers to its 2-bolt flange.
    Thanks.
    Apr 2011
    Dungowan
    I mite have some old Ross literature at work, tho that number dosn't ring a bell. Can look when go to work monday.
    Any idea the HP requirement of the boom spray?? What do you plan on driving it with?
