                                                5th May 2012, 05:52 PM
			285 on a 7" rim??
					Hi Guys. Just starting to get the shopping list rolling for my 2010 wagon. Lots of goodies ( & $). Tyres...I know, I know. Have read lots of info & threads and will was looking to 265's to replace the OEM when finally the time comes. I notice in the current edtion of 4WD Action (#160) the article Hidden Gems has the Fender with SVX edition alloys (I also grabbed a set at purchase) running 285/75R16???? These are also a 7" mag as per standard. Didn't think it was doable but would certainly look at the option. What say the brains trust?
 Miker.
                                                5th May 2012, 06:05 PM
					Hi mate, I am pretty sure you can, I have seen a few 110's running boost alloy's and 285's.
                                                5th May 2012, 06:10 PM
					When I searched this a few years ago, I think 1 or 2 tyres from Mickey Thompson were the only ones where the manufacturer recommended for down to 7" wide rims for that tyre. I don't know of any these days. Most require 8" rims, but thats not to say that they wont fit on a 7" rim.
Slunnie
 ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~ ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~
                                                5th May 2012, 06:12 PM
                                                #4
					Hi lambrover. No expert and I've always run stock on 3 fenders now. I've just not seen that spec tyre mentioned in general chat about options. What do you mean "boost" mags.
                                                5th May 2012, 07:15 PM
                                                #5
					Who has 285 tyres on there Defender?
 Try reading this thread, may shed some light.
                                                5th May 2012, 07:16 PM
                                                #6
					Boost alloys are the factory alloys
                                                5th May 2012, 08:16 PM
                                                #7
					I have 285/75/R16 BFG AT on my 16x7 Zu Rims  (Def90).
 They have been on for at least 3 years (only a year on the zu's) have been driven all around europe in all kinds of conditions covering many thousands of km's.  I have never had any issues or punctures which is great because they weigh a ton to get on and off the spare wheel carrier!
                                                6th May 2012, 02:22 AM
                                                #8
					Ran 285/75 BFG muds on 7" rims on my 90 for years. No issues.
                                                6th May 2012, 06:59 AM
                                                #9
					Hi,
 I had a set of 285/75's on boost alloy's on my 08' 110. They rubbed on the upper rear spring mounts when cornering or off road. Tassy was a killer, smoke in the cab
 Might pay to buy something with a resonable offset.
 Cheers, Tristan
                                                7th May 2012, 10:33 AM
                                                #10
					Miker,
 I agree with Tristan, the +33mm standard offset of Land Rover OEM Alloys (Boost, SVX and "Saw Tooth") just have the 285's running a bit too close to your coils and with a bit of sidewall flex or articulation they will rub. Having said that though, I've also seen a fair number of Defenders with 285's fitted on Boosts...
 If you've already spent the money on speciality OEM alloys I'd personally stay with 265 as max width.
 The ZU Alloys mentioned earlier in the thread is +12mm offset which by default moves the inside sidewall 21mm further out from the coil, hence no rubbing with 285's, which in fact fit fine on the 7" ZU's (BFG at least from experience).
