Results 1 to 4 of 4
Thread: Adjusting the Firewall to align the doors
    Aussie Expat in NZ
    Did a test fit of the doors today after replacing the firewall in my 110.
    Unfortunately.. they didn't. The latch passes in front of the strike... They need to go back 4-5mm!
    I'm guessing now, my only option is to adjust the firewall? I'm really not looking forward to doing it..
    What is the easiest way? I had a lot of difficulty getting the 2 washers I have in them now.. and I need to move the doors a lot..
    Has anyone moved the strikes forward with a washer or two there as well?
    Somewhat North of Cape York...
    There might be some play in the hinges you may be able to adjust. As for the strike, as far as I can recall there are some shims of different size available that can be adjusted to achieve adequate protrusion.
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    Aussie Expat in NZ
    I worked the hinges back as far as I can.
    Thats good news about the strike.. that will be much easier Are county and defender strikes the same? For some reason I think they may not be...
    Brisbane, Queensland
    When I rebuilt my 110 I had to cut the plastic block down on one side for the striker to fit properly.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
