Thread: 2010-->2012 UI software update
    May 2012
    Byron Bay
    Question 2010-->2012 UI software update
    Good Day Chaps,
    I have a 2010 3.0 V6 HSE Discovery 4. I looked at the photos of the revised 2012 Discovery 4 and have noticed that it has a new look and different UI on the Touchscreen.
    I've been looking for hours and cant find anything.
    Is it possible to update the software to the 2012 version? It looks much better in my opinion and it seems a bit more user friendly and straightforward.
    Cheers in advance
    As a second non related question. In the The AULRO Discovery 3/4 & RRS FAQ Thread it states that in order to trick your vehicle into Extended Suspension mode you can put it into off road hight, jam a wood block under the Chassis and lower the vehicle.
    Im tempted to try this out but im not sure about where exactly to put the wood. Is there a specific spot under the chassis which will minimise the chance of anything being damaged? Also by "jam" does it mean leaving no space between wood and chassis?
    I can post this as a different thread if necessary
    Aug 2008
    Sunshinecoast QLD
    hey J man
    Welcome
    They have a different screen/system,which according to the gurus on the UK sites not up gradeable
    Probably best to place the block of wood (or jack) under the jacking point, a bit shorter (say 20mm) to lower it onto,
    Really "the J man from Byron"
    Cheers Ken "the DEA man from Maleny" lol
    May 2012
    Byron Bay
    Quote Originally Posted by roamer View Post
    hey J man
    Welcome
    Cheers Ken "the DEA from Maleny" lol
    Oh allright, thats a pitty. Would've been great if it were. I don't find the system very user friendly. But then maybe thats just me. haha
    Cheers. Ill try it at one point
    Hahahaha, yeh thats me
    Thanks Ken
    Mar 2010
    back in WA
    Quote Originally Posted by The_J_Man
    Good Day Chaps,
    I have the 2011 HSE and Feel the same. It does not look like it can be done simply by updating software, however it might involve a new Hard drive/control box as all functions, controls and other car hard ware is the same (I think). I keep scanning the uk based sifts for a solution....hears hoping.
    The extended height trick is more easily accomplished if you use the LR jack, rather than a piece of wood. You can't guarantee that a particular bit of wood will fit under the car when on different road surfaces.
    Gordon
    May 2012
    Byron Bay
    Quote Originally Posted by gotaflat View Post
    Would be great if a Hard drive swap would do it. But I doubt they would make it that easy
    Only way to find it if it works is if a dealer or workshop tries it out and i doubt there is much chance of that.
    Thats the only thing I like about the 2012 LR4 (the software), the new Terrain Response selector and gear selector is a bit boring compared to the "older" version.
    Quote Originally Posted by gghaggis View Post
    Gordon
    Good Point.
    So I guess just wind the jack up to just below the jacking point, hold it in place so it doesn't fall over, and have someone else press the Suspension down button (or do it remotely).
    I've read the long thread about the extended height so quite informed now.
    Thanks Gordon
    Feb 2010
    Mount Martha
    Hey J Man,
    The ideal solution to raising the suspension is Llams.
    Just had it installed recently and highly recommend it.
    Cheers, Craig
    Sep 2011
    Central Tasmania (formerly Adelaide Hills)
    The exact site for placing the object that you lower the car onto is only important to prevent damage to the underside of the car. Anything that supports the car other than its wheels has the effect.
    I have recently been distacted by an interested and inquiring bystander while I hitched my trailer. I forgot to remove the jockey wheel and drove off. Within a few meters car was in extended mode, jockey wheel off the ground.... And I guessed what I'd done. No damage and I remain a happy camper.
    May 2012
    Byron Bay
    Quote Originally Posted by Disco4SE View Post
    Hey J Man,
    Cheers, Craig
    Thanks Craig
    I researched that. Its quite cool and would probably come in handy with lots of people but I wouldn't use it enough for it to pay out.
    Quote Originally Posted by Fred Nerk View Post
    haha, well they sure could make that system smarter Awkward it did that because a land rover engineer told me that the vehicle goes into extended mode if it senses weight loss on the air suspension (which is what would happen if the vehicle bellies out) or if something obstructs the car when its lowering itself. How would you not removing the jockey wheel cause that?
    Sep 2011
    The jockey wheel was on the ground and as I drove off on the undulating path the weight of the rear of the car and the ball weight of the trailer was transferred to the jockey wheel. The car "thought" it had bellied out and so went into extended mode. Not awkward at all. Going into extended mode saved damaging my Tregg hitch, my jockey wheel or worse.
    I would not recommend this method as a routine way to achieve extended height. It must have put a strain on the hitch.
