Results 1 to 10 of 11
Thread: 2 L excessive smoke?
    Aug 2008
    latrobe valley victoria
    ive done a wet/dry comp test on my engine and came up with the figures-->
    110 130 130 130 dry
    120 130 130 130 wet
    with new plugs and points it runs fairly smoothly and relitivly quitely but blows a thick cloud of smoke when the accelerator is pressed ...it was fuming out the breather but an oil change and a short drive reduced that substantialy
    my question is are the comp results acceptable ?
    and
    is the smoking a valve issue or a ring thing ?
    cheers mark
    Oct 2007
    Red Cliffs
    Smoke
    What colour is the smoke? Is the engine hot or cold?
    Black it just fuel.
    Blue/gray its oil.
    oil smoke
    Probably only the inlet valve guides are worn.
    I agree with Arthur. Worn valve guides and valve stem seals allow oil to be sucked down the valve stems when vacuum is high, i.e., when the throttle is closed, especially if the engine is turning fast. This oil is then carried into the combustion chambers when the throttle is opened, giving a cloud of blue/grey smoke that quickly stops. Similar smoke when pulling hard, especially at high rpm, will indicate worn rings and/or bore. Black smoke is unburnt fuel, usually a carburetter problem unless misfiring is noticeable. White smoke is steam, usually from coolant getting into the combustion chamber - definitely not good!
    Aug 2008
    Grey smoke , hot and cold , it's no worse under load .
    I am here: http://tapatalk.com/map.php?gviemu
    2002 defender 110 , 1955 86 inch
    Aug 2008
    I'm itching to pull it apart , but we're off for a 4 month drive on Friday morning ..
    It has been sitting for 5 yrs minimum and I'd imagine fairly gunged up ... Do you see any issues with the one cylinder being lower than the other 3 or is that acceptable ?
    Guess its easiest to start with the head when I get home
    I am here: http://tapatalk.com/map.php'tuy0it
    Aug 2008
    Just trailed it with someone else driving and it let's out a substantial puff as you change down gears or initially as you accelerate heavily then little while being driven sedately
    I am here: http://tapatalk.com/map.php?vygcdz
    Good motor
    The differences you found in the compression test are only a talking point and I wouldn't worry unless they get worse, then I would be looking for a burnt exhaust valve.
    From the workshop manual;
    Compression pressure (at starter motor cranking speed i.e., 300 r.pm. with engine hot and carburetter butterfly fully open)
    ...... 125 lb / sq. in. (8,8 kg / cm\2).
    Narrogin WA
    Quote Originally Posted by mfc View Post
    Buy yourself some engine oil detergent; the sort that is designed to strip gunge off rings, etc. I swear by Cost Effective Maintenance and Nulon - Google them.
    You will need to do an oil change and change the filter as well, probably during your trip, unless you get time before-hand.
    I don't think that 10 psi less on one cylinder is anything to worry about but clearing the rings etc. will make it run at its best,
    Cheers Charlie
    Does not seem to be a major problem. However, I would check the tappet clearance, especially the exhaust valves, as a tight tappet will soon result in a burnt valve.
