Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 120
Thread: Independent Suspension Design
    Dec 2011
    North Tambourine
    Here are the close to final design of my independent suspension trailer chassis.
    After all the trouble we had trying to get the camper on the tray of the truck we decided to design & build a trailer to take the camper, while i'm at it i can design in some extra storage.
    As it grows i will update.
    David
    99.87 MB
    Reminds me of the old VW swing arm suspension geometry! I'm guessing that it will need to adjust to a specific ride height with the varying loads. Have you considered hinging the suspension from a cross member rather than from the spine of the trailer - I just say this because it will always retain your chosen camber angle(s) and it may improve handling and stability. This may have already been discussed previously.
    Is the aim to reduce the ride height etc or for something cool and different? Irrespective, I like it.
    Slunnie
    you're airbags arent going to like that unless you put some wedge angle on to deal with the relative motion of the bag through its arc.
    I assume that you're going to fit self levelling airbag controls so that you dont have to worry about the wheel camber changing with varying load?
    Torres Straits
    if you run that design.
    I would run a sway bar to enable some left to right dynamic load sharing.
    I built up some swing arms on soft coils.
    Hated the varying camber, hated the lack of cross axle load sharing. Changed it over to a solid axle with triangulated 4 link. Tis now awesome.
    Name one solid engineering reason why a sigle axle trailer should have totally independently suspended hubs?
    S
    Gosnells
    Reminds me of a South Australian invention around 25+ years ago, "Sway-Allay".
    Aimed at the solid beam axle/cart-springs which was then the 'standard' for caravans.
    Basically, a pair of triangle arms hinged near the spine,attached to the axle at the apex and base....then the axle between the triangle bases (L and R) was cut out. Instant independant suspension !
    The original spring/shocks setup was left untouched.
    It certainly did as it was designed, reduced caravan swaying especially on the Bendy Bits.
    From fading memory, it was sold to a rustproofing company...who made a dog's breakfast of fitting them... and subsequently went out of business.
    Jul 2007
    Shock absorbers as required for length of suspension travel
    Maybe I should have said select either air bag A or B configuration for suspension travel.
    I note that truck bogies use the air bag outboard of the axle as per B. They are not after a lot of suspension travel but load handling so the lever (radius arm) can be used to their advantage on the airbags pressure handling capability to provide the necessary spring rate.
    Piggabeen (Tweed Heads)
    Suspension
    Mate dont try and re invent the wheel so to speak. I went down the same path and ended up building a solid axle on RR coils using RR trailing arms, A frame and small adjustable shocks. Works like a treat. Will put up a photo if you like.
    Justin
    Central Queensland
    The CRUISEMASTER® Range
    Vehicle components make some top quality gear, and I doubt you'll easily find any better trailer suspension kits.....
    Dec 2011
    North Tambourine
    Thanks guys for all you input about location & angle of the air springs.
    I'm not the person that builds an item my self just like the ones on the shelf. i believe that the design can be improved for my requirements, so i will give it a shot. I have taken some of your tips & added them into the design, but will be sticking to the original setup.
    The drawing are with the 3D CAD man, so real work on this project should start any day.
    I'l keep posting images & updates.
    David
    Torres Straits
    Have fun David,
    I like your attitude (sounds a bit like me) just be prepared to change it all around if it doesnt meet the mark!!! When I built up that boat trailer with swing arms that didnt work as well as I would like, the challenge was changing the axle and link config without altering my chassis mounts as the chassis had been hot dipped gal! Ended up working well - bit of good luck over good management I would think!
    With your centrally located swing arms, you will have some pretty serious longitudinal loads along the bushing as opposed to axial loads that bushes are made for. I would be making them super strong. What bushes will you use at the central chassis pivots? Will the bushes incorporate toe adjustment? Out of interest what section are you intending to build the swing arms out of?
    And another small tip, a trailer wont ever need more travel than 100mm up and 100mm down from ride height. By limiting your individual swing arm travel to 200mm at the hub you will control some of the wildly changing camber and funky dynamic loadings that central swing arms will result in. By the nature of a fixed central pivot at the tow hitch, trailer hubs never articulate relative to each other EXCEPT when one wheel or the other (not both) hits a significantly large object (hole or lump) at speed. Having another look at you design, with regards to lateral loads on the air spring and shock stroke, you might need to limit the travel even more than 200mm? Can the fancy CAD file be animated to show the angles when each swing arm travels up and down 100mm from the static ride height in the current images?
    Have fun!
    Steve
