                                                6th May 2012, 08:28 PM
			water seperator to 90 td5
					could anybody tell me how to connect a recor filter prior to existing filter on a td5 which fuel line do i connect too
                                                7th May 2012, 06:22 AM
					The 90 / 110 TD5 Fuel Filter already had a water separator built in.
 Why don't you just crack it now & again to let any water out.
 You could even buy a Discovery TD5 sedimenter switch for it instead of the Plain Jane Defender drain plug & wire the contacts to a idiot light to let you know if it needed draining..
                                                7th May 2012, 08:10 AM
					^agree...
 Dont mess with the factory system, its very effective...  You'll only add another complexity.
 Try and use quality, high turnover fuel stations is a good start.
 And as mentioned, factory filter has a separator, just crack it open occasionally.
                                                7th May 2012, 05:23 PM
                                                #4
			thanks
					thank for the tip i will stick with what is already perfect.
