Thread: UHF receive only chanels
    scott oz Guest
    Following adivce we're looking to buy the new Icom units IC440N which I understand are the new units.
    Aparently you can have up to 35 receive only chanels programeed in. "However" you need to have them programed by an authorised dealer.
    Given we are buying two we've done a deal where the channel's will be programed in for nothing however we need to identify the frequencies before we pick the units up.
    We live in Sydney and will likely travell north and south along the coast mostly . We are doing a Kimberly trip (6 weeks) so any outback channels would be good to have.
    We've no idea what receive only frequencies we should ask to be programmed in so would really appricate suggestions
    East-South-East Girt-By-Sea
    1.20 MB
    The receive only channels are usually for people who who use frequencies outside but close to the UHF CB frequencies, or amateur radio operators to monitor an amateur band while operating in the Citizens Band.
    This may be emergency service volunteers monitoring the frequencies used by their brigade and often land holders who have similar needs to know about local incidents where they may need to respond.
    For citizens band service these channels are usually redundant.
    Diana
    vk2fvrc
    May 2011
    G'day Scott,
    As Di says these "receive only" frequencies are often used by radio amateurs, EMS volunteers (CFA, RFS, SES, VRS, etc) so that they don't need to maintain a separate scanner to monitor the frequencies relevant to their pursuits.
    Our various state constabularies use frequencies covered by the receive only ranges on most UHF CB radios. Though since they are steadily migrating to APCO-25 secured digital usage of the frequencies this is less likely to be helpful as the days pass. Some of the rural (even those only just outside of the metropolitan area) still use analogue and unsecured units on these frequencies but they too are progressively migrating to digital usage.
    Each state has different laws on just the reception of police traffic on these frequencies and even if it's OK to monitor the frequency it may not be legal to act upon information received.
    For example, you may legally receive police radio traffic that indicates that there is a radar unit set up along the highway ahead of you. You do the right and proper thing and ensure that you are not speeding when you pass by its (now known) location. A case may still be made if you are found to have the ability to have received that information, in that you are in breach of federal law. Things have changed a lot in recent years.
    Mind you, the law of averages would suggest that you are unlikely to receive attention from said unit unless you are doing something else to warrant their intervention.
    Still, caveat emptor. Its certainly possible but do your own research on the potential legalities (or not) for your usage. Commercial and amateur frequencies are usually OK. Police and emergency services are a much dirtier colloidal solution.
    Iain
    Iain
    VK3BIT
    03MY Range Rover HSE Td6
    Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
    LROCV DTU member
    1.20 MB
    The ICOM 440N is still a very good set, you should be very happy with it.
    Diana
    Oct 2007
    wetherill park
    Yep as diana said they are good radio and will have all the CB channels preprogrammed the receive only is a bonus if you chosse to use them.
    PS: any state laws regarding radios both transceivers and receiver is trumped by feberal laws all radios come under the ACMA. Listening in to police can be interesting but as said acting on information recieved is illegal but terrorists and crims dont care
