Thread: 04D2 Susp lift 20,25,35,40,45,50 ?? Help.
    Oct 2010
    Tannum Sands
    Question 04D2 Susp lift 20,25,35,40,45,50 ?? Help.
    Hi Rovers, I am about to bring my stock 04D2 Classic TD5 into the shed and give Her some TLC. I am looking into a new coil spring and shock kit, but have run into the snag of which lift to choose. I am thinking the Dobinson 20mm lift, but gut feeling sais the TJM 25mm lift (an inch), ! would be just right. I dont think I need to go past the Dobinson 35mm, as my use of the vehicle probably does not require it.
    As there appear to be a good variety of lifts available, I would really appreciate any comment from those of you who have gone before me, before I commit to a purchase. Look forward to your advice. Shawry. CQ.
    Feb 2011
    Hobart, Tasmania, Australia
    Depends what your trying to achieve. How longs a piece of a string?
    Oct 2010
    Tannum Sands
    Quote Originally Posted by twr7cx View Post
    For me, the length of the string is a matter of taste, best served from the bitter end.
    Trying to achieve a moderate modification that will help the vehicle do its job.
    Stiffen it up a tad, improve potential sag in the rear. I was considering a set of coil assist air-springs fitted to the rear within the new coil springs, to have on hand for loaded vehicle and boat / trailer tow situations. I dont want to go into the area of fitting castor correction bushes, so seek advice on how other vehicles have gone, with 20, 25 or 35mm spring kits. Cheers.
    99.87 MB
    I would be looking to the higher end of the scale. There isn't a lot of value in doing a 20-35mm lift. With a Disco2 one of the other great benefits is the front bumpstop clearance, so even with stiffer springs it becomes more comfortable. I wouldn't go over that height though, you will start coming into other fitment and handling issues. 0-50mm is all well within range for the castor.
    Slunnie
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I went for 50mm Dobinson coils and Bilstein +50mm shocks. The springs are the Extra Heavy Dobinson as I have a fair bit of extra weight constantly on the vehicle. Before the weight went on they came out to a 65mm lift but then settled out to the 50mm mark.
    I have found with this setup;
    1. Touring and fast rough roads (corrugations and big holes) that it soaks up the bumps perfectly and gives a smooth ride. I tested it on the inland track at Bribie and the road out to Stanage Bay and at speed it was perfect.
    2. On slow crawling kind of work (rocks through creek beds etc) I get a lot more body roll compared to a softer coil setup.
    I have been tosing up the idea of going to 75mm flexi coils with poly air rears or alternatively a full air spring setup to help with the more adventerous driving and having the ability to level the car out when loaded for touring.
    I would say though that for touring the setup I have is great.
    Sep 2009
    And the answer is...
    It's twice as long as from one end to the middle.
    Jun 2011
    Have just completed the same process, went with toughdog HD coils, and non adjustable toughdog shocks front and rear, with a RTC toughdog steering damper..given me about 2" lift, smooth as handling, have towed a camper trailer (mainly onroad) with little noticeable sinking in the rear..very happy.
    Feb 2011
    Quote Originally Posted by Shawrover View Post
    Ok, so what part of the vehicles job is it currently not doing? I mean a lift doesn't really do that much - it provides longer suspension travel, increases your approach and departure angle and allows the fitment of larger diameter tyres (it the larger tyres that I find achieve the biggest difference in increasing ground clearance) - I notice none of these attributes seem to be on your requirement lift.
    None of these improvements require a suspension lift. Fitting new standard height heavy duty springs will stiffen the vehicle up, improve handling and sag in the rear. Air assist bags in the bag end will also improve rear sagging especially when loaded.
    My vehicle has a 4" suspension lift in order to accommodate the larger tyres. However, I wouldn't lift it a mm further than I have to, as the higher you go the more unstable it becomes and not as nice for on road travel.
    So the question therefore is, do you need a suspension lift at all?
    South Sydney
    Personally i would avoid suspension lifts if you can, i'm a P plater right now, and before i had my Discovery 1 i thought you needed to lift everything and have big mud tyres, interestingly enough i have actually lowered my car (thanks to the winch and nudge bar LOL) and i do some pretty serious 4wding IMO, the Disco (98 tdi) does everything flawlessly although it is fitted with a set of STT's (standard size) the only place i've ever got it stuck was a big mud hole (bigger tyres would have helped here). I have a set of rear coils to go in the front to bring it back to level, but right now i'm contemplating buying a D2 in which case i'll strip the D1 back and sell it as a perfect, stock car. I will put a 50mm lift in the D2 as i've already collected the big rear end of it once offroad and that will allow me to fit 265/75-16 tyres. In my opinion you should do the bare minimum to a car to make it do what you want, an example of this was a guy in a 4runner out at boat harbour the other day who had at least 4 inches of lift and 35 inch mud chucker tyres, here i was in my stock Disco with 40psi in the front tyres and 26 in the back snatching him out, he probably spent more than i spent on my Discovery in modifying his toyota but it is still just a whitegood, it really depends on the driver, but the engineers set a car up to be really good at 1 particular thing, stock is almost always better and more reliable, modifying causes problems. Just think about what you need, not what you want, unless of course you have excess to make things enjoyable, then by all means
    Sorry for the essay LOL
    Will
    Oct 2010
    Tannum Sands
    Smile
    Hi Gents, thanks for the salient comments. I think Will jnr has got a good head on His shoulders, and twr7cx sums it up. About ten years ago, I put new stock height king springs on my 4spd 83 4 dr Rangi, it totally revitalised the car and the guy at the suspension shop said it was the best RR he had ever driven. No height increase just a stiffer ride with new shocks. So, yes, I'll investigate a new spring, firmer, possibly the 20mm lift and the coil air spring in the rear.
    As Jnr sais, so much is to do with the driver. I dont mind the ol girl as she is, but, the rear end is definitely soft (ie springy, which we can attribute to shocks) but, the front end does appear to be a tad low, maybe the stock springs are feeling the weight of the TD5 after 8 years. What do you reckon ??
