Results 1 to 10 of 11
Thread: How long since you changed your pollen filter?
    mattg Guest
    Wow not sure how long since you changed you pollen filter but might be worth checking them. Changed these on a mates p38a tonight.
    Cheers Matt
    Oct 2007
    Williamstown, Victoria
    Wow, they must have been in there a long time, they are black!
    I usually do mine about every 12 months, it's amazing how much dust they pick up in that time. Better in the filters than in your lungs. A lot of non LR mechanics don't even know they exist, so there would be some around that have never been changed.
    Feb 2010
    Townsville, QLD
    That is bad! I change mine annually on the anniversary of my Rangie's purchase! At the same time I grease her nipples, rotate her tyres, bleed the brakes and give the diffs and tranny some new fluids!
    It's her birthday after all!
    Keithy
    Where is the best place to get new ones?
    Pete
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Check Ebay UK
    Quote Originally Posted by Marshall View Post
    Pete
    I give mine a bit of a touchup with a low powered vacuum cleaner then soak them overnight (filter- side down) in a small square plastic washing tub using about a tablespoon of wool detergent and 4L of water. Give them a bit of a shake occasionally..a lot of the dirt drops out.
    Then press them dry in a piece of old towling and let them air dry. They get a bit fragile when wet so handle carefully. Once they're dry -no worries... The trick is not to let them get too dirty...
    I have a set of 'new' replacements for 'just in case' ...have been recycling the current ones however for three years
    Feb 2010
    Townsville, QLD
    Island-4x4.co.uk is where I get mine!
    Yep, normally use ebay.co.uk I thought I would just check. But for 15pounds delivered I am not going to complain.
    Jul 2010
    Sydney/Balmain
    They are pretty easily washed out laundry detergent and a quick hit with a hose does the trick
    Replace your Plenum filter at the same time.
    I always look at P38s and consider the vehicle to be well maintained if the Plenum filter is present and in good order, 90% are not that i see about the place.
    mattg Guest
    Where is the plenum filter? Photo would be handy.
    I got mine from karcraft in silver water Sydney. I would always call these guys before offering os. Always get a good price. Cheers Matt
