Results 1 to 10 of 12
Thread: Just Bought Series III with Holden 186
    May 2012
    Wodonga, VIC
    Talking Just Bought Series III with Holden 186
    G'day guys and gals.
    Just bought my first Land Rover, an old Series III that has a Holden 186 in it. Will be picking it up next weekend.
    eBay Australia: Buy new & used fashion, electronics & home d
    Needs a fair bit of work, but I have nothing better to do with my time so I figured this will be a good filler and I'm bound to learn some things along the way. First thing I plan to do is check it over and make a list of things to do, then an order to do it.
    Any input/information appreciated.
    Rowan.
    Western Victoria
    Nice buy there.
    You're right, it needs work.
    That'll keep you enjoyably occupied for some time. Looking forward to the restoration thread.
    Mar 2012
    Porongurup Western Australia
    She's rough but she's got potential
    May 2012
    Wodonga, VIC
    I've been making a list of things to do, mostly getting up to scratch to drive.
    While surfing the net, I came across some info WRT the holden 186 engine in this vehicle, stating that it doesn't like going quickly with the 4 speed gearbox. What would be a good 5 speed gearbox to mate to this engine? Would the R380 work?
    Quote Originally Posted by AAFitArm View Post
    Your information regarding the engine not liking the gearing is correct. Whether it is a problem depends on what you plan to do with the vehicle. A good read of the various threads here on this subject will leave you much better informed (I suggest you go to the Series section and read the lot!). The alternatives would seem to be :
    1. Some Holden engines will operate satisfactorily with the existing gearing - either get one of these or modify your engine to this spec.
    2. Fit an overdrive. Simplest, easiest, most useful, but the most common ovedrive (Fairey) is a bit fragile and has some issues. Other (much better) overdrives exist but are either rare or quite expensive or both.
    3. Modify transfer case high range gearing. Fairly expensive, but may be justified if the transfer case needs overhauling anyway.
    4. Fit high ratio diffs. Relatively expensive and difficult since this will have a salisbury rear diff. Means your low range is higher too, which may not be what you want.
    5. Fit a different (five speed) gearbox. Not a routine change. There are no bolt on five speed boxes to match the existing transfer case. Fitting a later Landrover box and transfer case has the problem that they are all constant four wheel drive, meaning expensive and non-routine modifications to either the front axle or the transfer case.
    Hope this helps
    99.87 MB
    The other option which I would like to pursuit one day (but its not even registering on my priority list) is fitting the LT77 5 speed gearbox to a holden motor with a Holden/Series gearbox adaptor and then using the Ashcroft LT77/Series transfer case adaptor to retain the series transfer case. This combo is only 100mm longer than standard.
    http://www.ashcroft-transmissions.co...d&productId=83
    Slunnie
    Western Victoria
    Interesting!
    two doors one side
    and one door the other.
    What about putting it on a RRC chassis.
    3.5V8 with LT95.
    Maybe it would be best to see exactly what you have got before you decide what to do with it.
    May 2012
    Wodonga, VIC
    Yeah I'm going to wait and have a better look. Will let the forum know when I have some more solid data.
    May 2012
    Wodonga, VIC
    Well finally picked up my new toy. Looks... interesting to say the least. Wooden panels on the firewall, a mess in the back, rust all through the doors, dead battery. It does start however! All the glass is in good nick, everything moves that is supposed to move, some minor panel damage (bends/crumples, with one tear around the water tap panel).
    Mar 2012
    [QUOTE=Mick_Marsh;1682072]
    3.5V8 with LT95.
    Well thats what I'm doing and it's certainly a good option but requires some engineering. You do get the power of the V8, coil springs, Disc Brakes, Power Steering and possibly Air Cond.
