Ean , EGR means Exhaust GAS recirculation . If No Exhaust gas can get into the inlet tract then there there is no Recirculation. The rest of the EGR valve is only to cool the Exhaust gas ,so you dont have plus 200C -500C gas going into a Plastic manifold .(Ps you did remove both side pipes didnt you !)
Your only issue is the fault codes it throws and you knew that before you attempted the EGR blockoff ..
