Results 1 to 9 of 9
Thread: Factory A bar mounting bolts?
    Question Factory A bar mounting bolts?
    Hi, Does anyone have some factory A bar mounting bolts? Or know how to get hold of them? From memory (will try to find a pic) they are threaded on both ends. Perhaps someone has already put one on with out the proper kit and can advise an alternate solution.
    I have had one for a long time and now that I am finally doing a Junosi style discreet winch mount I need to have it on to be sure everything can work with it (cradle, number plate, wiring, etc.)
    Hoo-Roo,
    Dave.
    Dave,
    The instruction sheet doesn't show threaded both ends.
    Do you have the instructions or would you like me to send them to you? They are on the RAVE CD.
    I just had to go and search for "winch junosi" and found it: Removable winch mount
    How did I miss that one? I have a winch under my bench and it needs to be fitted,
    Thanks Ron, If its easy, can you tell which bits mount the centre section over the bumper? I don't have (or want) the headlight surround wings. Are any of those brackets req'd? I have Rave on CD will look it up in detail on the old shed computer tomorrow!
    On the Rave subject, is it available as a downloadable file instead of CD? I would like to put it straight onto "the pigs" netbook (which doesnt have a CD Drive).
    May 2008
    Dave - when we catch up in the next couple of weeks, I will show you how to mount the RAVE ISO file as a virtual CD on your netbook.
    Cheers, Paul.
    I just copied the RAVE disc to my PC and run that.
    Quote Originally Posted by DT-P38 View Post
    Aug 2010
    Pakenham
    These bolts are near impossible to get. I went to Bunnings and bought a set of matching high tensile bolts and spacers to suit.
    Gonna be down your way sometime on Thursday morning Andy, any chance of having a quick look at how you did it?
    Quote Originally Posted by redandy3575 View Post
    Hoo-Roo,
    Dave.
    Aug 2010
    Pakenham
    Absolutely. I've sent you a post.
