Results 1 to 10 of 20
Thread: 101 brake and clutch fluid reservoir modification
    Western Victoria
    Andy, this would be what AJ is sending you.
    You will need a "T" piece.
    You will also need to get another steel pipe made up to replace the threaded one at the reservoir (if you don't want to cut the original one).
    And fasion a bracket. (I've not done that yet.)
    This reservoir replaces the two with one. It is a solution for the problem of leakage in the master cylinder which causes the fluid to be transferred from one reservoir to the other. (Garry has connected his two reservoirs with a balance pipe for that problem.)
    That is a horrid piece of kit - why not just get the original item/s.
    Western Victoria
    I say, old bean, steady on.
    Hey Garry, have you got pics of that balance tube?
    Perth W.A.
    Fugly it is ... but if it saves the 25 year wait for parts happy days
    Order from the usual sources in the UK and you will have them within a week or so. They often are on ebay UK.
    Western Victoria
    Note that I haven't mounted it to a bracket yet. Didn't bother as I was getting some of the proper ones.
    Perth W.A.
    I think alisport could be of assistance if you wanted an alloy one.
    Haven't got round to getting anywhere near the reservoir yet, been too busy getting the old girl dressed, she was hanging around in the back yard with just her undies on!
    Sent from my iPhone using Telepathy
    Western Victoria
    Yep. Know what it is like. There are always other things to do.
    Perth W.A.
    I am in the middle of omg at the moment the back is stripped except for the ceiling panels and the Fiberglass behind then we have the rest of the rear wiring to take out.
    After which I should be on the partition and remove a bit of that, then start stripping the cab.
    Then it's fitting a new wiring loom and associated switches then fit the lights all while this is going on I am looking at getting the carbs cleaned and overhauled wow!
    Where are you at mick? Or are you still on the Mercs ?
    Western Victoria
    Progress is slow but that's ok.
    The fuel tank has just come back from re-constructive surgery. I have a new series three fuel sender (I hope will fit) and a new fuel pump. I'm looking for some new screws and gasket. I'll run a POR15 fuel tank repair kit through it when the weather gets warmer and dryer. And it's painted black.
    The Mercs are proving to be a bit of a drain on resources. Many visits to the expensive care ward.
    The W112 is almost ready to pick up after having the cold start system rebuilt, some air suspension leaks plugged, engine and gearbox mounts replaced and just about every rubber bit in the suspension replaced. I'm told it drives beautifully with no clunking noises. The W109 needs valve stem seals replaced and A/C gas leaks plugged. And the indicators are intermittent.
    The Tracks are almost ready to be registered. The Crump & Cornish needs much brake work but I want to register that soon too. Oh, I'm also looking at a No5.
    And then there is the new project. Then the new new project that is about to enter the negotiating stage.
    Then I'll get stuck into the 101's.
    I have so many projects I am always entertained.
    Oh, and today a mate told me about a series 2a with tool brackets that needs saving. Going cheap apparently. I'll check that one out. Hope it's a six cylinder.
