If the main gearbox is in gear the wheel won't turn.
If the handbrake is on the wheel won't turn
The only way to test if the CDL is engaged is to jack up one wheel,
Handbrake OFF, Main Gearbox OUT OF GEAR .
With CDL engaged jacked up wheel won't turn
With CDL disengaged wheel will turn, again gearbox must be in neutral , (unless you have the strength to turn the engine over by turning the wheel)
regardless of wether light is on or off, its where the lever is that matters.
					 I thought I could trust that blasted light.
					 putting it in 1st when parking up is a subconscious habit of mine...
