The sump plate takes about 2 minutes to remove and about 3 minutes to put back on - so why would you bother cutting a hole in it.  I think with a hole in it a lot of dirt would build up under the engine.
Bbyer - on the TDV6 the oil filter is on top if the engine so removing the sump plate is to only gain access to the sump plug.
