All Landrover wheels up to the RR Classic and Disco 1 fit, in that the stud pattern is the same. Some wheels will not fit because they conflict with either the larger hub protrusion of the Series or the drum brakes. Disco 2 on and P38A on wheels have a different stud pattern.  No other maker has used the same stud pattern.
As well as the stud pattern you need to consider the width, offset and overall diameter of the tyres. First is to check the maximum allowed variation in your state. Also, consider whether you really want to fit wider tyres in the absence of power steering. The most common option is the Disco 1 steet wheels, which will fit without direct problems. But note that the offset on them will result in significantly increased turning circle, perhaps not a problem with a swb, but could be with a lwb.
