Well what 110 do you have
I am guessing by the fact your are talking about a 300tdi disco then you have a 300 tdi one
If you change the transfer box to disco one , no problem as all the disco 1 had CDL is was just the early Disco 2 that did not .
But easier just to get a full auto box and transfer box out of a disco one. The best way to fit the auto to defender is to get an aftermarket 50th kit
This is my brothers defender
Wolf doffs are 4 pin and rare and don't think you will have one if you have a 300tdi unless you or someone has changed it . Which in Aus it is cheaper and easier to put in an Arb locker which will make a rover diff 4 pin anyway. It will have the same diff as 90's Disco1 and late RRC'S have front and rear as standard
The Salisbury axle is closely related to the Dana 60 axle ( parts are interchangeable and dimensions the same) . If you have a 300tdi it will be a 24 spins if a later one and disc brakes. If you want to get this stronger then the quickest way is to use high tough shafts and an Arb 4 pin locker
Hope this helps
Ali
