Results 1 to 3 of 3
Thread: 93 110 front diff change over
    Apr 2012
    Newcastle nsw
    I after some advise if possible.
    I am currently building a 300tdi 110.
    I have a laminated and braced front diff/axle housing which i want to keep but i am running 10 spline internals from the 93 def.
    I do however have a 95 disco which I am wrecking and would like to know if then internals are the 24 spline internals and if these will all fit into the housing that I have off the defender and what else I would need to do for them to fit.
    Are the crown gearing different to the sauls diff I have in the back of the def
    Any help would be greatly appreciated
    Welcome
    Hi Ausfender
    Welcome aboard to the forum.
    You can change the diffs and half shafts over, to achieve that.
    The gaskets are the same for all axle housings through the years for both Discovery series one's and Defenders.
    Ratio's are the same also.
    Look into the possibility of fitting True Trac centres to your diffs.
    http://www.ebay.com.au/itm/True-Trac...item1c24e41958
    Apr 2012
    Newcastle nsw
    Thanks heaps for the advise.
    I'll certainly look at the true trac centre. I was thinking of running a air locker in the rear.
