Results 1 to 8 of 8
Thread: Dash Brake Lights
    bear666 Guest
    Dash Brake Lights
    Need Some Ideas. Hand brake light,Traction Control and ABS light flash on when i apply the brake's. They only stay on for a second. Brakes all work fine. Anyone have any ideas?
    Apr 2011
    Melbourne, Australia
    Replacing the ABS accumulator fixed this exact fault on my 1995 4.0L
    Easy DIY job. Just remember to depressurise the system first.
    Pat.
    Agreed.
    Feb 2010
    Townsville, QLD
    Depressurising = pumping brake pedal 30ish times with the ignition off, correct me if I'm wrong?
    Coogee, South of Fremantle, WA
    Pretty much right. After the 30 pumps Rave says wait 60 seconds and give it another 4 pumps
    Sep 2011
    I have a spare accumulator you can try if that would help you, 0400 429283
    Ken
    bear666 Guest
    dash brake lights
    Thanks for that, will try this weekend. Peter
    also make sure the connectors into the ECU (located up the firewall behind the glove box) are properly located...had this problem and was planning to get a new ECU... found loose connection by chance...
