Results 1 to 2 of 2
Thread: Replacement lenses for SIIa
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Quote Originally Posted by Jock The Rock View Post
    Message - AULRO Classifieds
    Chasing a set (2) of the glass lense indicators for my Series I
    I want to get it back on the road, I used to have a set of these on my Series IIA and I assume they were Landrover items
    If you can't readily find originals, check the lenses available in this catalogue Car Builder Solutions Ltd. Kit car parts. Spares and accessories for the car builder enthusiast..
    Peter
    East-South-East Girt-By-Sea
    1.20 MB
    ]Message - AULRO Classifieds
    Jock
    You probably know that indicators were not a standard part on most S1. The most common retrofit is the Lucas 594 with the amber dome lens and a single filament, although some people use a clear dome lens and a double filament for side and flasher (white flashers are permitted on a pre ADR vehicle like the Series 1)
    Holden | Lighting | Side and Flasher Lamps | L594 Flasher Lamp Single Contact
    If you want similar for the rear but don't want to drill the large hole required, you can fit an aftermarket L594/flat which uses a festoon globe. Check some have a plastic lens, but you can get the glass L594 lens as a spare part.
    Holden | Lighting | Side and Flasher Lamps | Flat Base Flasher Lamp Single Filament
    BTW the side lamps of the 1954-58 were L489 - which are similar to the L488 but had a wider stainless bezel as can be seen by the first image.
    sidelamp model Lucas L489-1 :: Vintage Car Parts
    In fact the double contact side/flasher (stop/tail) bub holder assembly for all the L488/L489/L594 lamps can be fitted into the L489 to keep the original appearence.
    Before you go to the UK, try Kevin Baker Classic Parts ph 07 54944221 fax 07 54944114 Qld or Anthony Pearson in Adelaide Classic & Vintage Bulbs
    Diana
