I know it will be in here somewhere but I gave up.
Can someone please tell me the size of the pop rivet used to replace the bottom door seal on a defender. 110 1998, if needed.
I found something on the web that said 4.8mm but I cant be sure.
I am using the original type door seal due to rust repairs under the doors.
Thank you all
98 Defender 110 tdi Boomer
'morning tonic,
If you were to look back through your 2,147,483,747 posts, you'd possibly find the answer to your own question
Failing you having the time to do that though, I'd say they were 3/16" rivets.
Roger
