Results 1 to 10 of 27
Thread: How smooth is your 3.0 at idle?
    NSW SW Slopes
    I noticed an engine-related harshness at idle when I started the D4 at the dealers after open heart surgery (and software updated to the latest levels) and thought an exhaust rubber must be slightly out of place. I finally got to have a poke around today and discovered that the engine has a roughness that can even be felt at the end of the exhaust pipes. The pipes are hanging freely and probably weren't touched anyway when the body was removed. The harmonic balancer is moving about a little but I don't know if that's cause or effect. There appears to be a regular thump amongst lesser vibrations making me think that an injector might not be quite right, but perhaps all the 3.0 engines are like this.
    Any comments?
    Sep 2011
    Minyama
    My D4 was smooth as initially but I've noticed it getting slowly rougher at ideal especially when stopped and in drive. The vehicle only has 5k on it so at this stage I'm putting it down to the engine loosing up and the idle speed increasing although I would have thought it was electronically fixed. It's due for it's health check so I'll see how it comes back from that.
    LGM's Avatar
    LGM is offline Master Silver Subscriber
    May 2010
    Dongara on the Mid West Coast WA
    How Smooth - Real Smooth
    Coming up to 26,000km on the clock for my Sep 11 D4 3.0L. It runs well, is quiet, with no noticable roughness. It has also had a software update at 13,500km. The only noticable difference after that was (in my opinion) an improvement in the auto-trans gear changes.
    Feb 2010
    Mount Martha
    I noticed an engine-related harshness at idle when I started the D4 at the dealers after open heart surgery but perhaps all the 3.0 engines are like this.
    Hi Graeme, I know a few people that have the 3.0 Lt engines including myself. No complaints so far, in fact one bloke I know has clocked over 240,000 Klm's.
    Cheers, Craig
    Aug 2008
    Sunshinecoast QLD
    Hi Graeme
    My 3lt (65k, 08/2009 build) has just been at dealers for a rough/miss idle,
    when cold at start
    if I slowly raise revs,. at 1100 rpm it is most noticable.
    Dealer did reproduce, and has sent enquiry to LRA.
    Will let you know what they say
    Cheers Ken
    NSW SW Slopes
    Thanks Ken. I only checked slightly higher revs so will do some more checking. I don't think the roughness is only when cold but will monitor that too. It may be that the engine has had this roughness all the while but that there is now a misplaced hose or something else after the body lift that is transmitting the roughness to the body, although I think the roughness shouldn't exist anyway. Having the harmonic balancer moving at the same time on such a new and modern engine makes me nervous too, especially as its purpose is usually to smooth harmonics created by the addition of ancilliary equipment at higher revs, not the engine itself. I thought the Faultmate might show injector information but not so. Warranty is running out with 80K on the clock so there's some urgency in getting it resolved.
    Aug 2008
    Sunshinecoast QLD
    Hi Graeme
    A follow up on rough idle, mine was rough at about 1100 rpm, more noticable when cold, but still there when warm in the end run.
    LRA wanted dealer to do live data test and send to them.
    Came back with everything OK with engine, must be a vibration from somewhere.
    Dealer has been over it with electronic ear, and reckons it is an ordinary engine mount.
    They get replaced tomorrow, will see then
    Cheers Ken
    NSW SW Slopes
    I discovered on Monday whilst using CC at 110 kph up a rather steep incline on the freeway that the vibration was considerably worse, to the extent that the vibration through the steering wheel made all my fingers tingle until the crest when less power was produced. I still haven't had a proper look to see if something is out of place after the body-off job but must do so before any damage is done if that is the cause. I'd be surprised if mine's cause is an engine mount as it started with the body-off job but that could be a coincidence.
    May 2011
    Orange Grove WA
    Bloody hell......that does not sound good Graeme.
    Looks as though someone has certainly not put the body back on correctly.
    Brett......
    Jul 2009
    Lake Macquarie NSW
    Bugger that!!!
    I dont want a car that needs its body to be raised off the chassis for maintenance.!!!!! Thinking of updating the D2 in the next couple of years but a D4? No dont think so. New Ranger, D max, Navara..........mmm.
    Robbo
